Dear All,
I am seeking your guidance on table table 5.3 of ASME VIII, Div.2.
On table 5.3 are reported several loads combination in design and operating condition with related allowable stressed.
1 - Self-restraining load T
Recently, I have seen several reports where temperature is neglected (while I was use to see in reports combination (12) (Po+To), but never (3) (P+T) of table 5.3).
Explanation is that when equipment is in temperature, temperatures are uniformly distributed and we can assume load T as negligible (as also described in of table 5.2).
Even if I may agree, in heat exchangers I believe that differential temperature on tube-sheet or across pass partition is a load that cannot be neglected.
What is your opinion on that?
2 - How to correlated allowable stress of table 5.3 with stress classification of table 5.6?
Max allowable stress in design condition as per table 5.3 is Spl.
However, for example, at the junction between head and shell I can classify the stress as Q as per table 5.6.
It means that in that location stress in design condition can be neglected and that can be analyzed them in operating condition only?
It also mean that differential thermal load (for example) can be analyzed in operating condition and can be neglected in design one?
Hope I have not made too much confusion.
