Assembly Constraints, cannot center a cylinde to anoter cylinder
Bogdan1985
72
a new surprise in the morning. I have a railing post which should be centered to a hole in the floor.
All of the sudden I cannot touch/align/ center line to centerline. And even not face touch to face.
A coworker says its something with the save options. Which are the correct save option combination to get it back?
Thx
You can open the assemblies constraints command, but not select anything? If so, check your selection filter setting and selection priority.
www.nxjournaling.com
Make sure the two components are fully loaded (not just partially).
Jerry J.
UGV5-NX11
Thank you Cowski and Jerry1423.
You both are right. But I could neither change the priority nor the load options.
I reinstalled NX and it works now. Everyday a new surprise!
Thanks again.
Be carefull with load options on your site.
May be the file load_options.def is shared by another colleague. So you problem could appeared again
Didier Psaltopoulos
