Assign Attributes From Excel
mbrown1000
I apologize if this has already been covered but I have been searching for a while and can't find anything.
I'm looking for something like the AssignAttributesForTooltips journal in the sample NX Open apps that come with the installation, except I want to assign attributes for each part in an assembly (and the assembly part itself).
Let's say I have an assembly named 123 which contains parts AAA, BBB, and CCC, and an Excel sheet that lists the part name in column A and another separate attribute for each part name in column B (like cell A1 contains 123 and cell B1 contains 456, cell A2 contains AAA and cell B2 contains ZZZ, and so on). I want to cycle through each part, look up the appropriate cell in the sheet based on the part name attribute, and then create a new attribute with the value in the corresponding cell in column B.
I think I could eventually figure out how to do this, but I thought I would check and see if maybe it had already been done first.
Hi mbrown1000
i have seen journal to feel attributes at assembly level and part level.
Do you get the something for assigning attributes from Excel?
tHANKS.
