Some Curious Guy
I do not know if its only me noticing this but I have some confusion regarding assigning SA-516 plates to Curve C or Curve D of fig UCS-66,Sec VIII Div 1.
Let us assume we have a SA-516 Gr 65 plate.
If the plate is not normalized it will fall under Curve B. This is clear.
If the plate is normalized it will fall under Curve D. This is also clear but I need confirmation from you all
If the plate is Quenched and tempered it will fall under Curve D. This is also clear but I need confirmation from you all
Confusion is with Curve C. If I am reading it correctly the following plates are assigned to Curve C
1) Fine Grain Practice + Normalized
2) Normalized and Tempered
3) Liquid Quenched and Tempered.
If you notice both Curve C and Curve D can lay claim to 1) Fine Grain Practice + Normalized and 2) Liquid quenched and Tempered plates.
I am not a metallurgist so please excuse me if I draw the below conclusion for SA-516 plates assuming I read Curve C and Curve D requirements correctly.
1) Fine Grain Practice ( FGP ) and Normalized plates have less toughness as compared to just normalized plates. Since Curve C is assigned to FGP + Normalized plates and curve D is assigned to Normalized plates.
2) Tempering reduces the toughness of Normalized plates since Tempered and Normalized plates is assigned to Curve C and Curve D is assigned to just Normalized plates
3) Liquid Quenched and tempered plates have less toughness as compared to Quenched ( I assume Air / inert gas Quenching ) and tempered plates.
I request you to highlight where I am reading the code incorrectly. Apologies if my queries appear stupid. As I said I am not a metallurgist and I graduated from university a very long time ago.
