Assigning Weight and CG 2
jzecha
Aerospace
Is there a way in Catia to apply a weight to an All Cat Part and assign the CG instead of using the measured CG?
I have Engineering from a Customer where they provided me an All Cat Part of their assembly and gave me the CG and weight.
I am designing a tool that attaches to their Engineering and I would like to figure out the new weight and CG of their Engineering and my Tool together.
My tool has material properties applied and CG is correct, but I need a way to apply a weight and assign the CG to their provided CG.
One method that I have seen used is to create a simple geometry (i.e. a sphere) of arbitrary size with its center at the stated CG. Then apply a material to that geometry to achieve a suitable mass. That could be a custom material that has a density declared, or a standard material and manipulate the volume of your geometry to achieve the correct mass. Calculating the size of the sphere or the necessary material density is straightforward.
Search the forum or CATIA Online Documentation for Inertia Equivalents. Should provide the answer you need.
I've used the method MarkAF said on lots of lifting equipment projects and it works just fine :)
After some trial and error, I figured out how to use that, it got my exactly what i needed.
Thank You
