Assistance on science project: Hybrid renewable energy system
hanahkoh
Student
Hello, I am currently a student in high school who is trying to design a hybrid renewable energy system incorporating solar, wind, and thermal energy. The main purpose of this project is to reduce the amount of environmental damage renewable energy sources deal and contribute to sustainable energy technology. The main part that I need help on would be the designing and building, I am not proficient in this field, so a person who is more knowledgeable would be great.
Some information:
Solar energy is utilized by basic monocrystalline solar panels.
Thermal energy is utilized by a parabolic solar cooker that turns a turbine with steam from the pressure cooker. (This is the main part I need help with)
Wind energy is utilized by cross axis wind turbines.
It would be great is anyone could provide any information, advice, or criticisms to this project. Thank you very much.
"surely" as a high school project "no one" is expecting you to design the complete system. I think being able to sketch out the components of the system, like a flow chart, based on some idea. The idea you have (looks like using solar energy to create electricity). Now the confusion seems to creep in ... you mention "monocrystalline solar panels" ... if these are PV panels then they create electricity directly. But then you talk about a pressure cooker ... like the solar energy heats a fluid (not necessarily water, what property of the fluid do you think you want to emphasize ?) which turns a turbine to create electricity ... a more novel concept. Something similar has been put into practice in SoCal, using mirrors to concentrate the solar radiation (I could tell you, but I think it's better for you to find out things for yourself, or at least try to). This would lead you to some of the issues encountered and this I think is the point of the project ... to have an idea then to think about pros and cons and real world experience, and why you think your idea addresses some of these problems.
Thank you so much, i'll put that into consideration. The sources are all connected to motors. The turbine is spun by the steam that comes out from the pressure cooker once it is heated up by the parabolic mirrors. The solar panels are used as storage energy, like a battery. Yes, I've addressed most of the pros and cons and currently working out the kinks. Is the system in SoCal a concentrated solar power system? If so, I have researched it. Thank you once again for the advice.
You may want to research Stirling engines.
A novel idea for better understanding and possibly extra marks:
Research the environmental damage done by the manufacture of each type of renewable solution.
Add that information to your design flow chart.
More extra marks:
Research the source of your present energy supplies, electric and natural gas, or other.
Show the actual saving in carbon equivalents your design may produce.
More extra marks:
Thank you so much, I will research those topics. I am designing a prototype, so I will definitely need to demonstrate the saving. I have already researched the environmental impact. Thank you again for your input.
"Is the system in SoCal a concentrated solar power system?" ... yes, it uses mirrors not PV cells.
"The solar panels are used as storage energy, like a battery." ... not what I meant ... PV panels are a source of electricity, like batteries; but they aren't a storage device.
For your consideration
Pierre
Oh yes, I understand what you mean. I apologize, there were a few miscommunications. English is not my first language. Thank you.
Pierre
I will look through these, thank you so much.
An anecdote;
Environmental protection is nothing new to California.
Many many years ago, when battery technology for EVs was based on lead-acid batteries, California passed a law demanding that by a certain deadline, a percentage of new cars sold in California must be electric.
It was quietly pointed out to the supporters of the bill that with the existing technology, almost all of the planed reduction in pollution gained by a shift to would electric would be offset up front by the pollution created by the manufacture of the lead acid batteries.
The legislation was never enforced and quietly died.
[Anecdote/off]
it may be interesting to investigate the emissions associated with the manufacture of various types of alternate energy hardware.
eg: How much initial time of energy production will be needed to offset the manufacturing emission?
An anecdote;
[Anecdote/off]
That is a good point to research. I appreciate it thank you.
