ASTM A206-T4 Fatigue Property Data 2
materials2018
Materials
Sep 4, 2018
4
My FEA team is looking for fatigue property data for ASTM A206 Aluminum in T4 condition. Are there online resources that could contain this data?
Thanks.
WHY A201.0-T4 ?????????? All data I reviewed states 'use in -T7 temper'...
1. ASTM B686-18 Standard Specification for Aluminum Alloy Castings, High-Strength
A201.0 (c)
(c) Alloy A201.0 is intended for use in the –T7 temper, which provides a high level
of resistance to stress-corrosion cracking when properly heat treated. In other
tempers, alloy A201.0 may exhibit susceptibility to stress-corrosion cracking.
Additionally, its tendency for hot shortness may make alloy A201.0 unsuitable in
some casting designs.
2. MMPDS-10
A201.0-T7 AMS-A-21180 and AMS 4229
Table 3.8.1.0(b). Design Mechanical and Physical Properties of A201.0 Aluminum Alloy Casting
Figure 3.8.1.1.8(a). Best-fit ε/N curves, cyclic stress-strain curve, and mean stress
relaxation curve for A201.0-T7 casting at 75F.
Figure 3.8.1.1.8(b). Best-fit ε/N curves, cyclic stress-strain curve, and mean stress
reduction curve for A201.0-T7 casting at 200F.
Figure 3.8.1.1.8(c). Best-fit 0/N curves, cyclic stress-strain curve, and mean stress
relaxation curve for A201.0-T7 casting at 350EF.
Regards, Wil Taylor
o Trust - But Verify!
Wil,
Thank you for the response, but I am looking for A206 not A201.
Dohoooo [purpleface], never mind...
WHAT ASTM spec are You referring to for A206-T4 castings?
Regards, Wil Taylor
