Pipe and Fittings
Petroleum
- May 21, 2018
- 3
I am looking at a B366 Tee that the outlet is partially formed by the manufacturer and they have also welded a pup to complete the tee dimensional requirements. The main body of the tee is seamless. The weld has be radiographed. The MTR of the fitting only states the type, size and ASTM specification. The fitting is marked as WPNC-WX 400 B366.
How does this fitting comply with ASTM B366, ASME B16.9 and be marked WPNC-WX?
Wouldn't it be non-compliant with B16.9 section 1.3 and thereby not be permitted to be marked as mentioned?
