Atached a Blockstyler journal created with NX11. the Ok/Apply buttons not work as expected ?
Ehaviv
Computer
IL
Hi
The atached Blockstyler journal not react as expected.
The Ok and the Apply buttons not become active as expected.
theDlxFileName = "C:\MarkBrdComponents.dlx"
Code:
'  WARNING!!  This file is overwritten by the Block UI Styler while generating
'  the automation code. Any modifications to this file will be lost after
'  generating the code again.
'       Filename:  C:\MarkBrdComponents.vb
'        This file was generated by the NX Block UI Styler
'        Created by: me
'              Version: NX 11
'              Date: 07-25-2018  (Format: mm-dd-yyyy)
'              Time: 13:25 (Format: hh-mm)
'  Purpose:  This TEMPLATE file contains VB.NET source to guide you in the
'  construction of your Block application dialog. The generation of your
'  dialog file (.dlx extension) is the first step towards dialog construction
'  within NX.  You must now create a NX Open application that
'  utilizes this file (.dlx).
'  The information in this file provides you with the following:
'  1.  Help on how to load and display your Block UI Styler dialog in NX
'      using APIs provided in NXOpen.BlockStyler namespace
'  2.  The empty callback methods (stubs) associated with your dialog items
'      have also been placed in this file. These empty methods have been
'      created simply to start you along with your coding requirements.
'      The method name, argument list and possible return values have already
'      been provided for you.
'These imports are needed for the following template code
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.BlockStyler
'Represents Block Styler application class
Public Class MarkBrdComponents
    'class members
    Private Shared theSession As Session
    Private Shared theUI As UI
    Private theDlxFileName As String
    Private theDialog As NXOpen.BlockStyler.BlockDialog
    Private myDialog As NXOpen.BlockStyler.Group' Block type: Group
    Private grpCompsMarks As NXOpen.BlockStyler.Group' Block type: Group
    Private facecollectorBrdFace As NXOpen.BlockStyler.FaceCollector' Block type: Face Collector
    Private bodycollectorCompBody As NXOpen.BlockStyler.BodyCollector' Block type: Body Collector
    Private multilinestringShowText As NXOpen.BlockStyler.MultilineString' Block type: Multiline String
    Private objectcolorpickerMarkColor As NXOpen.BlockStyler.ObjectColorPicker' Block type: Color Picker
    Private grpMarkSearch As NXOpen.BlockStyler.Group' Block type: Group
    Private stringSearchText As NXOpen.BlockStyler.StringBlock' Block type: String
    Private objectcolorpickerSearchColor As NXOpen.BlockStyler.ObjectColorPicker' Block type: Color Picker
    Private actionbuttonMarkSearch As NXOpen.BlockStyler.Button' Block type: Button
    Private markClearAll As NXOpen.BlockStyler.Group' Block type: Group
    Private btnSwitch As NXOpen.BlockStyler.Button' Block type: Button
#Region "Block Styler Dialog Designer generator code"
    'Constructor for NX Styler class
    Public Sub New()
        Try
            theSession = Session.GetSession()
            theUI = UI.GetUI()
            theDialog = theUI.CreateDialog(theDlxFileName)
            theDialog.AddApplyHandler(AddressOf apply_cb)
            theDialog.AddOkHandler(AddressOf ok_cb)
            theDialog.AddUpdateHandler(AddressOf update_cb)
            theDialog.AddInitializeHandler(AddressOf initialize_cb)
            theDialog.AddFocusNotifyHandler(AddressOf focusNotify_cb)
            theDialog.AddEnableOKButtonHandler(AddressOf enableOKButton_cb)
            theDialog.AddDialogShownHandler(AddressOf dialogShown_cb)
        Catch ex As Exception
            '---- Enter your exception handling code here -----
            Throw ex
        End Try
    End Sub
#End Region
    '------------------------------- DIALOG LAUNCHING ---------------------------------
    '    Before invoking this application one needs to open any part/empty part in NX
    '    because of the behavior of the blocks.
    '    Make sure the dlx file is in one of the following locations:
    '        1.) From where NX session is launched
    '        2.) $UGII_USER_DIR/application
    '        3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
    '            recommended. This variable is set to a full directory path to a file
    '            containing a list of root directories for all custom applications.
    '            e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_BASE_DIR\ugii\menus\custom_dirs.dat
    '    You can create the dialog using one of the following way:
    '    1. Journal Replay
    '        1) Replay this file through Tool->Journal->Play Menu.
    '    2. USER EXIT
    '        1) Create the Shared Library -- Refer "Block UI Styler programmer's guide"
    '        2) Invoke the Shared Library through File->Execute->NX Open menu.
    Public Shared Sub Main()
        Dim theMarkBrdComponents As MarkBrdComponents = Nothing
        Try
            theMarkBrdComponents = New MarkBrdComponents()
            ' The following method shows the dialog immediately
            theMarkBrdComponents.Show()
            theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
        Finally
            If theMarkBrdComponents IsNot Nothing Then
                theMarkBrdComponents.Dispose()
                theMarkBrdComponents = Nothing
            End If
        End Try
    End Sub
    ' This method specifies how a shared image is unloaded from memory
    ' within NX. This method gives you the capability to unload an
    ' internal NX Open application or user  exit from NX. Specify any
    ' one of the three constants as a return value to determine the type
    ' of unload to perform:
    '    Immediately : unload the library as soon as the automation program has completed
    '    Explicitly  : unload the library from the "Unload Shared Image" dialog
    '    AtTermination : unload the library when the NX session terminates
    ' NOTE:  A program which associates NX Open applications with the menubar
    ' MUST NOT use this option since it will UNLOAD your NX Open application image
    ' from the menubar.
    Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
        'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
         Return CType(Session.LibraryUnloadOption.Immediately, Integer)
        ' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
    End Function
    ' Following method cleanup any housekeeping chores that may be needed.
    ' This method is automatically called by NX.
    Public Shared Sub UnloadLibrary(ByVal arg As String)
        Try
        End Try
    End Sub
    'This method shows the dialog on the screen
    Public Sub Show()
        Try
            theDialog.Show
        End Try
    End Sub
    'Method Name: Dispose
    Public Sub Dispose()
        If theDialog IsNot Nothing Then
            theDialog.Dispose()
            theDialog = Nothing
        End If
    End Sub
    '---------------------Block UI Styler Callback Functions--------------------------
    'Callback Name: initialize_cb
    Public Sub initialize_cb()
        Try
            myDialog = CType(theDialog.TopBlock.FindBlock("myDialog"), NXOpen.BlockStyler.Group)
            grpCompsMarks = CType(theDialog.TopBlock.FindBlock("grpCompsMarks"), NXOpen.BlockStyler.Group)
            facecollectorBrdFace = CType(theDialog.TopBlock.FindBlock("facecollectorBrdFace"), NXOpen.BlockStyler.FaceCollector)
            bodycollectorCompBody = CType(theDialog.TopBlock.FindBlock("bodycollectorCompBody"), NXOpen.BlockStyler.BodyCollector)
            multilinestringShowText = CType(theDialog.TopBlock.FindBlock("multilinestringShowText"), NXOpen.BlockStyler.MultilineString)
            objectcolorpickerMarkColor = CType(theDialog.TopBlock.FindBlock("objectcolorpickerMarkColor"), NXOpen.BlockStyler.ObjectColorPicker)
            grpMarkSearch = CType(theDialog.TopBlock.FindBlock("grpMarkSearch"), NXOpen.BlockStyler.Group)
            stringSearchText = CType(theDialog.TopBlock.FindBlock("stringSearchText"), NXOpen.BlockStyler.StringBlock)
            objectcolorpickerSearchColor = CType(theDialog.TopBlock.FindBlock("objectcolorpickerSearchColor"), NXOpen.BlockStyler.ObjectColorPicker)
            actionbuttonMarkSearch = CType(theDialog.TopBlock.FindBlock("actionbuttonMarkSearch"), NXOpen.BlockStyler.Button)
            markClearAll = CType(theDialog.TopBlock.FindBlock("markClearAll"), NXOpen.BlockStyler.Group)
            btnSwitch = CType(theDialog.TopBlock.FindBlock("btnSwitch"), NXOpen.BlockStyler.Button)
        End Try
    End Sub
    'Callback Name: dialogShown_cb
    'This callback is executed just before the dialog launch. Thus any value set
    'here will take precedence and dialog will be launched showing that value.
    Public Sub dialogShown_cb()
        Try
            '---- Enter your callback code here -----
        End Try
    End Sub
    'Callback Name: apply_cb
    Public Function apply_cb() As Integer
        Dim errorCode as Integer = 0
        Try
            errorCode = 1
        End Try
        apply_cb = errorCode
    End Function
    'Callback Name: update_cb
    Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
        Try
            Dim text2search As String
            Dim mark_text As String
            Dim face_color As Integer
            Dim body_color As Integer
            Dim search_color As Integer
            Dim aBody As Body
            Dim aFace As Face
            If block Is facecollectorBrdFace Then
            '---- Enter your code here -----
              bodycollectorCompBody.Focus
              aFace = facecollectorBrdFace.GetSelectedObjects(0)
              aFace.UnHighlight
              face_color = objectcolorpickerMarkColor.GetValue(0)
              aFace.Color = face_color
              aFace.RedisplayObject()
            ElseIf block Is bodycollectorCompBody Then
              aBody = bodycollectorCompBody.GetSelectedObjects(0)
              aBody.UnHighlight
              body_color = objectcolorpickerMarkColor.GetValue(0)
              aBody.Color = body_color
              aBody.RedisplayObject()
            ElseIf block Is multilinestringShowText Then
            ElseIf block Is objectcolorpickerMarkColor Then
            ElseIf block Is stringSearchText Then
            ElseIf block Is objectcolorpickerSearchColor Then
            ElseIf block Is actionbuttonMarkSearch Then
              search_color = objectcolorpickerSearchColor.GetValue(0)
              mark_text = stringSearchText.Value
              theUI.NXMessageBox.Show("mark_text", NXMessageBox.DialogType.Information, "mark_text = stringSearchText.Value = " & mark_text)
              theUI.NXMessageBox.Show("search_color", NXMessageBox.DialogType.Information, "search_color = objectcolorpickerSearchColor.GetValue(0) = " & search_color.ToString)
            ElseIf block Is btnSwitch Then
            End If
        End Try
        update_cb = 0
    End Function
    'Callback Name: ok_cb
    Public Function ok_cb() As Integer
        Try
            errorCode = apply_cb()
            errorCode = 1
        End Try
        ok_cb = errorCode
    End Function
    'Callback Name: focusNotify_cb
    'This callback is executed when any block (except the ones which receive keyboard entry such as Integer block) receives focus.
    Public Sub focusNotify_cb(ByVal block As BlockStyler.UIBlock, ByVal focus As Boolean)
        Try
        End Try
    End Sub
    'Callback Name: enableOKButton_cb
    'This callback allows the dialog to enable/disable the OK and Apply button.
    Public Function enableOKButton_cb() As Boolean
        enableOKButton_cb = True
        Try
        End Try
    End Function
    'Function Name: GetBlockProperties
    'Returns the propertylist of the specified BlockID
    Public Function GetBlockProperties(ByVal blockID As String) As PropertyList
        GetBlockProperties = Nothing
        Try
            GetBlockProperties = theDialog.GetBlockProperties(blockID)
        End Try
    End Function
End Class
 https://files.engineering.com/getfile.aspx?folder=540ee22b-daba-41fc-91ff-cc54619bf255&file=MarkBrdComponents.dlx
In the above post the files .vb and .dlx
are attached
Please help ln knowing how to make
the ok,apply buttons to be active.
only if I select a body they comes active
but if I select a face or peak a coloror click a button they does not become active.
Thank you in advanced
Correction: only if you satisfy BOTH required inputs (a body AND a face, the selection steps marked with a red asterisk) do the OK and apply buttons become active. This is consistent with other NX dialog boxes. If one of the selections isn't required, set its step status property to "optional" (default is "required").
www.nxjournaling.com
Hi Cowski and very thank you.
how I do that to optional and what
it mean optional is it possible for
the optional to get an object or
its become a dummy.
Hi Cowski.
I found it !
and I make one satisfied and one optional.
and that works greatly.
its hard to see all that details
for one that start work with blockstyler.
I browsed the documentation but
maybe I missed that
Thank you very much.
