Dear all,
I have, based on thread Link, adapted the Journal and added some more Attributes to fill-in or automatic filled in.
Only with the TextBox11.Text = workPart.GetStringAttribute(myAttributeTitle(10)) i have an issue.
In my NX file the Attribute is not a String Attribute, but of the Type Number.
Does anybody knows a solution for this?
Using NX11, no Database
Code:
'Release "QUA_Set_PartFileAttributes.vb"
'Drive:\Customer\XXXX\Mould\Final\XXXX-YYY.prt
'Drive:\Customer\XXXX\Tool\XXXX-YYY-ZZZ.prt
'This journal updates, based on the OS File Name, several extracted Attributes
'FILE_PATH
'FILE_NAME
'Part_Spec
'PART_NAME
'MOULD_NR
'CUSTOMER_NAME
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
Dim theSession As Session = Session.GetSession()
Public workPart As Part = theSession.Parts.Work
Sub Main()
workPart.SetAttribute("FILE_PATH", GetFilePath())
workPart.SetAttribute("FILE_NAME", GetFileName())
workPart.SetAttribute("Part_Spec", (GetFilePath() & GetFileName())&".prt")
workPart.SetAttribute("PART_NAME", GetFilePartName())
'workPart.SetAttribute("MOULD_NR", GetFileMould())
workPart.SetAttribute("CUSTOMER_NAME", GetFileCustomerName())
Dim myDialog As New Dialog1
myDialog.myPart = workPart.FullPath
myDialog.ShowDialog()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
Function GetFileName()
Dim strPath as String
Dim strPart0 as String
Dim pos0 as Integer
'get the full file path
strPath = workPart.fullpath
'get the part file name
pos0 = InStrRev(strPath, "\")
strPart0 = Mid(strPath, pos0 + 1)
strPath = Left(strPath, pos0)
'strip off the ".prt" extension
strPart0 = Left(strPart0, Len(strPart0) - 4)
GetFileName = strPart0
End Function
Function GetFilePath()
Dim pos0 as Integer
GetFilePath = strPath
End Function
Function GetFilePartName()
Dim pos0 as Integer
strPath = Right(strPath, pos0)
'strip off the "XXXX "
strPart0 = Right(strPart0, Len(strPart0) - 5)
GetFilePartName = strPart0
End Function
Function GetFileCustomerName()
Dim strPart1 as String
Dim strPart2 as String
'Dim strPart3 as String
'Dim strPart4 as String
Dim pos0 as Integer
Dim pos1 as Integer
Dim pos2 as Integer
'Dim pos3 as Integer
'Dim pos4 as Integer
strPart0 = Left(strPath, pos0 - 1)
pos1 = InStrRev(strPart0, "\")
strPart1 = Right(strPart0, Len(strPart0) - 3)
pos2 = InStr(strPart1, "\")
strPart2 = Left(strPart1, pos2 - 1)
'pos3 = InStrRev(strPart2, "\")
'strPart3 = Left(strPart2, pos3 - 1)
'pos4 = InStrRev(strPart3, "\")
'strPart4 = Left(strPart3, Len(strPart3) - 5)
GetFileCustomerName = strPart2
End Function
'Function GetFileMould()
'Dim strPath as String
'Dim strPart0 as String
'Dim strPart1 as String
'Dim strPart2 as String
'Dim pos0 as Integer
'Dim pos1 as Integer
'Dim pos2 as Integer
'strPath = workPart.fullpath
'pos0 = InStrRev(strPath, "\")
'strPart0 = Left(strPath, pos0 - 1)
'pos1 = InStrRev(strPart0, "\")
'strPart1 = Right(strPart0, Len(strPart0) - 3)
'pos2 = InStr(strPart1, "\")
'strPart2 = Mid(strPart1, pos2 + 1)
'pos3 = InStr(strPart2, "\")
'GetFileMould = strPart3
'End Function
End Module
Public Class Dialog1
Public myPart As String
Private myAttributeTitle(23) As String
Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Try
workPart.SetAttribute(myAttributeTitle(0), TextBox1.Text)
Catch ex As Exception
MsgBox(myAttributeTitle(0) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(1), TextBox2.Text)
MsgBox(myAttributeTitle(1) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(2), TextBox3.Text)
MsgBox(myAttributeTitle(2) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(3), TextBox4.Text)
MsgBox(myAttributeTitle(3) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(4), TextBox5.Text)
MsgBox(myAttributeTitle(4) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(5), TextBox6.Text)
MsgBox(myAttributeTitle(5) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(6), TextBox7.Text)
MsgBox(myAttributeTitle(6) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(7), TextBox8.Text)
MsgBox(myAttributeTitle(7) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(8), TextBox9.Text)
MsgBox(myAttributeTitle(9) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(9), TextBox10.Text)
End Try
Try
workPart.SetAttribute(myAttributeTitle(10), TextBox11.Text)
MsgBox(myAttributeTitle(10) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(11), TextBox12.Text)
MsgBox(myAttributeTitle(11) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(12), TextBox13.Text)
MsgBox(myAttributeTitle(12) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(13), TextBox14.Text)
MsgBox(myAttributeTitle(13) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(14), TextBox15.Text)
MsgBox(myAttributeTitle(14) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(15), TextBox16.Text)
MsgBox(myAttributeTitle(15) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(16), TextBox17.Text)
MsgBox(myAttributeTitle(16) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(17), TextBox18.Text)
MsgBox(myAttributeTitle(17) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(18), TextBox19.Text)
MsgBox(myAttributeTitle(18) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(19), TextBox20.Text)
MsgBox(myAttributeTitle(19) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(20), TextBox21.Text)
MsgBox(myAttributeTitle(20) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(21), TextBox22.Text)
MsgBox(myAttributeTitle(21) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(22), TextBox23.Text)
MsgBox(myAttributeTitle(22) & " : " & ex.Message)
End Try
Try
workPart.SetAttribute(myAttributeTitle(23), TextBox24.Text)
MsgBox(myAttributeTitle(23) & " : " & ex.Message)
End Try
Me.Close()
End Sub
Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
Private Sub Dialog1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Me.Text = myPart
myAttributeTitle(0) = "CUSTOMER_NAME"
myAttributeTitle(1) = "PROJECT_NAME"
myAttributeTitle(2) = "CUSTOMER_PART_NR"
myAttributeTitle(3) = "ITEM_NR_CMS"
myAttributeTitle(4) = "MOULD_NR"
myAttributeTitle(5) = "DESCRIPTION.1"
myAttributeTitle(6) = "DESCRIPTION.2"
myAttributeTitle(7) = "MATERIAL.1"
myAttributeTitle(8) = "MATERIAL.2"
myAttributeTitle(9) = "SHRINKAGE"
myAttributeTitle(10) = "SHOT_SIZE"
myAttributeTitle(11) = "TREATMENT"
myAttributeTitle(12) = "QUANTITY"
myAttributeTitle(13) = "PART_NAME"
myAttributeTitle(14) = "TOL_GROUP"
myAttributeTitle(15) = "DRAWN"
myAttributeTitle(16) = "DATE_DRAWN"
myAttributeTitle(17) = "CHECKED"
myAttributeTitle(18) = "DATE_CHECKED"
myAttributeTitle(19) = "APPROVED"
myAttributeTitle(20) = "DATE_APPROVED"
myAttributeTitle(21) = "RELEASE_STATUS"
myAttributeTitle(22) = "FILE_NAME"
myAttributeTitle(23) = "FILE_PATH"
Try
TextBox1.Text = workPart.GetStringAttribute(myAttributeTitle(0))
Catch ex As ApplicationException
'attribute does not exist
TextBox1.Text = ""
End Try
Label1.Text = myAttributeTitle(0)
Try
TextBox2.Text = workPart.GetStringAttribute(myAttributeTitle(1))
TextBox2.Text = ""
End Try
Label2.Text = myAttributeTitle(1)
Try
TextBox3.Text = workPart.GetStringAttribute(myAttributeTitle(2))
TextBox3.Text = ""
End Try
Label3.Text = myAttributeTitle(2)
Try
TextBox4.Text = workPart.GetStringAttribute(myAttributeTitle(3))
TextBox4.Text = ""
End Try
Label4.Text = myAttributeTitle(3)
Try
TextBox5.Text = workPart.GetStringAttribute(myAttributeTitle(4))
TextBox5.Text = ""
End Try
Label5.Text = myAttributeTitle(4)
Try
TextBox6.Text = workPart.GetStringAttribute(myAttributeTitle(5))
TextBox6.Text = ""
End Try
Label6.Text = myAttributeTitle(5)
Try
TextBox7.Text = workPart.GetStringAttribute(myAttributeTitle(6))
TextBox7.Text = ""
End Try
Label7.Text = myAttributeTitle(6)
Try
TextBox8.Text = workPart.GetStringAttribute(myAttributeTitle(7))
TextBox8.Text = ""
End Try
Label8.Text = myAttributeTitle(7)
Try
TextBox9.Text = workPart.GetStringAttribute(myAttributeTitle(8))
TextBox9.Text = ""
End Try
Label9.Text = myAttributeTitle(8)
Try
TextBox10.Text = workPart.GetStringAttribute(myAttributeTitle(9))
TextBox10.Text = ""
End Try
Label10.Text = myAttributeTitle(9)
Try
TextBox11.Text = ""
End Try
Label11.Text = myAttributeTitle(10)
Try
TextBox12.Text = workPart.GetStringAttribute(myAttributeTitle(11))
TextBox12.Text = ""
End Try
Label12.Text = myAttributeTitle(11)
Try
TextBox13.Text = workPart.GetStringAttribute(myAttributeTitle(12))
TextBox13.Text = ""
End Try
Label13.Text = myAttributeTitle(12)
Try
TextBox14.Text = workPart.GetStringAttribute(myAttributeTitle(13))
TextBox14.Text = ""
End Try
Label14.Text = myAttributeTitle(13)
Try
TextBox15.Text = workPart.GetStringAttribute(myAttributeTitle(14))
TextBox15.Text = ""
End Try
Label15.Text = myAttributeTitle(14)
Try
TextBox16.Text = workPart.GetStringAttribute(myAttributeTitle(15))
TextBox16.Text = ""
End Try
Label16.Text = myAttributeTitle(15)
Try
TextBox17.Text = workPart.GetStringAttribute(myAttributeTitle(16))
TextBox17.Text = ""
End Try
Label17.Text = myAttributeTitle(16)
Try
TextBox18.Text = workPart.GetStringAttribute(myAttributeTitle(17))
TextBox18.Text = ""
End Try
Label18.Text = myAttributeTitle(17)
Try
TextBox19.Text = workPart.GetStringAttribute(myAttributeTitle(18))
TextBox19.Text = ""
End Try
Label19.Text = myAttributeTitle(18)
Try
TextBox20.Text = workPart.GetStringAttribute(myAttributeTitle(19))
TextBox20.Text = ""
End Try
Label20.Text = myAttributeTitle(19)
Try
TextBox21.Text = workPart.GetStringAttribute(myAttributeTitle(20))
TextBox21.Text = ""
End Try
Label21.Text = myAttributeTitle(20)
Try
TextBox22.Text = workPart.GetStringAttribute(myAttributeTitle(21))
TextBox22.Text = ""
End Try
Label22.Text = myAttributeTitle(21)
Try
TextBox23.Text = workPart.GetStringAttribute(myAttributeTitle(22))
TextBox23.Text = ""
End Try
Label23.Text = myAttributeTitle(22)
Try
TextBox24.Text = workPart.GetStringAttribute(myAttributeTitle(23))
TextBox24.Text = ""
End Try
Label24.Text = myAttributeTitle(23)
End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Dialog1
Inherits System.Windows.Forms.Form
'Form overrides dispose to clean up the component list.
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Me.TableLayoutPanel1 = New System.Windows.Forms.TableLayoutPanel()
Me.OK_Button = New System.Windows.Forms.Button()
Me.Cancel_Button = New System.Windows.Forms.Button()
Me.Label1 = New System.Windows.Forms.Label()
Me.TextBox1 = New System.Windows.Forms.TextBox()
Me.TextBox2 = New System.Windows.Forms.TextBox()
Me.Label2 = New System.Windows.Forms.Label()
Me.TextBox3 = New System.Windows.Forms.TextBox()
Me.Label3 = New System.Windows.Forms.Label()
Me.TextBox4 = New System.Windows.Forms.TextBox()
Me.Label4 = New System.Windows.Forms.Label()
Me.TextBox5 = New System.Windows.Forms.TextBox()
Me.Label5 = New System.Windows.Forms.Label()
Me.TextBox6 = New System.Windows.Forms.TextBox()
Me.Label6 = New System.Windows.Forms.Label()
Me.TextBox7 = New System.Windows.Forms.TextBox()
Me.Label7 = New System.Windows.Forms.Label()
Me.TextBox8 = New System.Windows.Forms.TextBox()
Me.Label8 = New System.Windows.Forms.Label()
Me.TextBox9 = New System.Windows.Forms.TextBox()
Me.Label9 = New System.Windows.Forms.Label()
Me.TextBox10 = New System.Windows.Forms.TextBox()
Me.Label10 = New System.Windows.Forms.Label()
Me.TextBox11 = New System.Windows.Forms.TextBox()
Me.Label11 = New System.Windows.Forms.Label()
Me.TextBox12 = New System.Windows.Forms.TextBox()
Me.Label12 = New System.Windows.Forms.Label()
Me.TextBox13 = New System.Windows.Forms.TextBox()
Me.Label13 = New System.Windows.Forms.Label()
Me.TextBox14 = New System.Windows.Forms.TextBox()
Me.Label14 = New System.Windows.Forms.Label()
Me.TextBox15 = New System.Windows.Forms.TextBox()
Me.Label15 = New System.Windows.Forms.Label()
Me.TextBox16 = New System.Windows.Forms.TextBox()
Me.Label16 = New System.Windows.Forms.Label()
Me.TextBox17 = New System.Windows.Forms.TextBox()
Me.Label17 = New System.Windows.Forms.Label()
Me.TextBox18 = New System.Windows.Forms.TextBox()
Me.Label18 = New System.Windows.Forms.Label()
Me.TextBox19 = New System.Windows.Forms.TextBox()
Me.Label19 = New System.Windows.Forms.Label()
Me.TextBox20 = New System.Windows.Forms.TextBox()
Me.Label20 = New System.Windows.Forms.Label()
Me.TextBox21 = New System.Windows.Forms.TextBox()
Me.Label21 = New System.Windows.Forms.Label()
Me.TextBox22 = New System.Windows.Forms.TextBox()
Me.Label22 = New System.Windows.Forms.Label()
Me.TextBox23 = New System.Windows.Forms.TextBox()
Me.Label23 = New System.Windows.Forms.Label()
Me.TextBox24 = New System.Windows.Forms.TextBox()
Me.Label24 = New System.Windows.Forms.Label()
Me.TableLayoutPanel1.SuspendLayout()
Me.SuspendLayout()
'TableLayoutPanel1
Me.TableLayoutPanel1.Anchor = CType((System.Windows.Forms.AnchorStyles.Bottom Or System.Windows.Forms.AnchorStyles.Right), System.Windows.Forms.AnchorStyles)
Me.TableLayoutPanel1.ColumnCount = 2
Me.TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Controls.Add(Me.OK_Button, 0, 0)
Me.TableLayoutPanel1.Controls.Add(Me.Cancel_Button, 1, 0)
Me.TableLayoutPanel1.Location = New System.Drawing.Point(277, 618) '(277, 332)
Me.TableLayoutPanel1.Name = "TableLayoutPanel1"
Me.TableLayoutPanel1.RowCount = 1
Me.TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
Me.TableLayoutPanel1.Size = New System.Drawing.Size(146, 29)
Me.TableLayoutPanel1.TabIndex = 0
'OK_Button
Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.OK_Button.Location = New System.Drawing.Point(3, 3)
Me.OK_Button.Name = "OK_Button"
Me.OK_Button.Size = New System.Drawing.Size(67, 23)
Me.OK_Button.TabIndex = 0
Me.OK_Button.Text = "OK"
'Cancel_Button
Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Cancel_Button.Location = New System.Drawing.Point(76, 3)
Me.Cancel_Button.Name = "Cancel_Button"
Me.Cancel_Button.Size = New System.Drawing.Size(67, 23)
Me.Cancel_Button.TabIndex = 1
Me.Cancel_Button.Text = "Cancel"
'TextBox1
Me.TextBox1.Location = New System.Drawing.Point(149, 23)
Me.TextBox1.Name = "TextBox1"
Me.TextBox1.Size = New System.Drawing.Size(234, 20)
Me.TextBox1.TabIndex = 2
'Label1
Me.Label1.Location = New System.Drawing.Point(9, 19)
Me.Label1.Name = "Label1"
Me.Label1.Size = New System.Drawing.Size(134, 26)
Me.Label1.TabIndex = 1
Me.Label1.Text = "Attribute:"
Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox2
Me.TextBox2.Location = New System.Drawing.Point(149, 49)
Me.TextBox2.Name = "TextBox2"
Me.TextBox2.Size = New System.Drawing.Size(234, 20)
Me.TextBox2.TabIndex = 4
'Label2
Me.Label2.Location = New System.Drawing.Point(9, 45)
Me.Label2.Name = "Label2"
Me.Label2.Size = New System.Drawing.Size(134, 26)
Me.Label2.TabIndex = 3
Me.Label2.Text = "Attribute:"
Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox3
Me.TextBox3.Location = New System.Drawing.Point(149, 75)
Me.TextBox3.Name = "TextBox3"
Me.TextBox3.Size = New System.Drawing.Size(234, 20)
Me.TextBox3.TabIndex = 6
'Label3
Me.Label3.Location = New System.Drawing.Point(9, 71)
Me.Label3.Name = "Label3"
Me.Label3.Size = New System.Drawing.Size(134, 26)
Me.Label3.TabIndex = 5
Me.Label3.Text = "Attribute:"
Me.Label3.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox4
Me.TextBox4.Location = New System.Drawing.Point(149, 101)
Me.TextBox4.Name = "TextBox4"
Me.TextBox4.Size = New System.Drawing.Size(234, 20)
Me.TextBox4.TabIndex = 8
'Label4
Me.Label4.Location = New System.Drawing.Point(9, 97)
Me.Label4.Name = "Label4"
Me.Label4.Size = New System.Drawing.Size(134, 26)
Me.Label4.TabIndex = 7
Me.Label4.Text = "Attribute:"
Me.Label4.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox5
Me.TextBox5.Location = New System.Drawing.Point(149, 127)
Me.TextBox5.Name = "TextBox5"
Me.TextBox5.Size = New System.Drawing.Size(234, 20)
Me.TextBox5.TabIndex = 10
'Label5
Me.Label5.Location = New System.Drawing.Point(9, 123)
Me.Label5.Name = "Label5"
Me.Label5.Size = New System.Drawing.Size(134, 26)
Me.Label5.TabIndex = 9
Me.Label5.Text = "Attribute:"
Me.Label5.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox6
Me.TextBox6.Location = New System.Drawing.Point(149, 153)
Me.TextBox6.Name = "TextBox6"
Me.TextBox6.Size = New System.Drawing.Size(234, 20)
Me.TextBox6.TabIndex = 12
'Label6
Me.Label6.Location = New System.Drawing.Point(9, 149)
Me.Label6.Name = "Label6"
Me.Label6.Size = New System.Drawing.Size(134, 26)
Me.Label6.TabIndex = 11
Me.Label6.Text = "Attribute:"
Me.Label6.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox7
Me.TextBox7.Location = New System.Drawing.Point(149, 179)
Me.TextBox7.Name = "TextBox7"
Me.TextBox7.Size = New System.Drawing.Size(234, 20)
Me.TextBox7.TabIndex = 14
'Label7
Me.Label7.Location = New System.Drawing.Point(9, 175)
Me.Label7.Name = "Label7"
Me.Label7.Size = New System.Drawing.Size(134, 26)
Me.Label7.TabIndex = 13
Me.Label7.Text = "Attribute:"
Me.Label7.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox8
Me.TextBox8.Location = New System.Drawing.Point(149, 205)
Me.TextBox8.Name = "TextBox8"
Me.TextBox8.Size = New System.Drawing.Size(234, 20)
Me.TextBox8.TabIndex = 16
'Label8
Me.Label8.Location = New System.Drawing.Point(9, 201)
Me.Label8.Name = "Label8"
Me.Label8.Size = New System.Drawing.Size(134, 26)
Me.Label8.TabIndex = 15
Me.Label8.Text = "Attribute:"
Me.Label8.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox9
Me.TextBox9.Location = New System.Drawing.Point(149, 231)
Me.TextBox9.Name = "TextBox9"
Me.TextBox9.Size = New System.Drawing.Size(234, 20)
Me.TextBox9.TabIndex = 18
'Label9
Me.Label9.Location = New System.Drawing.Point(9, 227)
Me.Label9.Name = "Label9"
Me.Label9.Size = New System.Drawing.Size(134, 26)
Me.Label9.TabIndex = 17
Me.Label9.Text = "Attribute:"
Me.Label9.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox10
Me.TextBox10.Location = New System.Drawing.Point(149, 257)
Me.TextBox10.Name = "TextBox10"
Me.TextBox10.Size = New System.Drawing.Size(234, 20)
Me.TextBox10.TabIndex = 20
'Label10
Me.Label10.Location = New System.Drawing.Point(9, 253)
Me.Label10.Name = "Label10"
Me.Label10.Size = New System.Drawing.Size(134, 26)
Me.Label10.TabIndex = 19
Me.Label10.Text = "Attribute:"
Me.Label10.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox11
Me.TextBox11.Location = New System.Drawing.Point(149, 283)
Me.TextBox11.Name = "TextBox11"
Me.TextBox11.Size = New System.Drawing.Size(234, 20)
Me.TextBox11.TabIndex = 22
'Label11
Me.Label11.Location = New System.Drawing.Point(9, 279)
Me.Label11.Name = "Label11"
Me.Label11.Size = New System.Drawing.Size(134, 26)
Me.Label11.TabIndex = 21
Me.Label11.Text = "Attribute:"
Me.Label11.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox12
Me.TextBox12.Location = New System.Drawing.Point(149, 309)
Me.TextBox12.Name = "TextBox12"
Me.TextBox12.Size = New System.Drawing.Size(234, 20)
Me.TextBox12.TabIndex = 24
'Label12
Me.Label12.Location = New System.Drawing.Point(9, 305)
Me.Label12.Name = "Label12"
Me.Label12.Size = New System.Drawing.Size(134, 26)
Me.Label12.TabIndex = 23
Me.Label12.Text = "Attribute:"
Me.Label12.TextAlign = System.Drawing.ContentAlignment.MiddleRight
' Tot hier OK
'TextBox13
Me.TextBox13.Location = New System.Drawing.Point(149, 335)
Me.TextBox13.Name = "TextBox13"
Me.TextBox13.Size = New System.Drawing.Size(234, 20)
Me.TextBox13.TabIndex = 26
'Label13
Me.Label13.Location = New System.Drawing.Point(9, 331)
Me.Label13.Name = "Label13"
Me.Label13.Size = New System.Drawing.Size(134, 26)
Me.Label13.TabIndex = 25
Me.Label13.Text = "Attribute:"
Me.Label13.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox14
Me.TextBox14.Location = New System.Drawing.Point(149, 361)
Me.TextBox14.Name = "TextBox14"
Me.TextBox14.Size = New System.Drawing.Size(234, 20)
Me.TextBox14.TabIndex = 28
'Label14
Me.Label14.Location = New System.Drawing.Point(9, 357)
Me.Label14.Name = "Label14"
Me.Label14.Size = New System.Drawing.Size(134, 26)
Me.Label14.TabIndex = 27
Me.Label14.Text = "Attribute:"
Me.Label14.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox15
Me.TextBox15.Location = New System.Drawing.Point(149, 387)
Me.TextBox15.Name = "TextBox13"
Me.TextBox15.Size = New System.Drawing.Size(234, 20)
Me.TextBox15.TabIndex = 28
'Label15
Me.Label15.Location = New System.Drawing.Point(9, 383)
Me.Label15.Name = "Label15"
Me.Label15.Size = New System.Drawing.Size(134, 26)
Me.Label15.TabIndex = 27
Me.Label15.Text = "Attribute:"
Me.Label15.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox16
Me.TextBox16.Location = New System.Drawing.Point(149, 387)
Me.TextBox16.Name = "TextBox16"
Me.TextBox16.Size = New System.Drawing.Size(234, 20)
Me.TextBox16.TabIndex = 30
'Label16
Me.Label16.Location = New System.Drawing.Point(9, 383)
Me.Label16.Name = "Label16"
Me.Label16.Size = New System.Drawing.Size(134, 26)
Me.Label16.TabIndex = 29
Me.Label16.Text = "Attribute:"
Me.Label16.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox17
Me.TextBox17.Location = New System.Drawing.Point(149, 413)
Me.TextBox17.Name = "TextBox17"
Me.TextBox17.Size = New System.Drawing.Size(234, 20)
Me.TextBox17.TabIndex = 32
'Label17
Me.Label17.Location = New System.Drawing.Point(9, 409)
Me.Label17.Name = "Label17"
Me.Label17.Size = New System.Drawing.Size(134, 26)
Me.Label17.TabIndex = 31
Me.Label17.Text = "Attribute:"
Me.Label17.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox18
Me.TextBox18.Location = New System.Drawing.Point(149, 439)
Me.TextBox18.Name = "TextBox18"
Me.TextBox18.Size = New System.Drawing.Size(234, 20)
Me.TextBox18.TabIndex = 34
'Label18
Me.Label18.Location = New System.Drawing.Point(9, 435)
Me.Label18.Name = "Label18"
Me.Label18.Size = New System.Drawing.Size(134, 26)
Me.Label18.TabIndex = 33
Me.Label18.Text = "Attribute:"
Me.Label18.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox19
Me.TextBox19.Location = New System.Drawing.Point(149, 465)
Me.TextBox19.Name = "TextBox19"
Me.TextBox19.Size = New System.Drawing.Size(234, 20)
Me.TextBox19.TabIndex = 36
'Label19
Me.Label19.Location = New System.Drawing.Point(9, 461)
Me.Label19.Name = "Label19"
Me.Label19.Size = New System.Drawing.Size(134, 26)
Me.Label19.TabIndex = 35
Me.Label19.Text = "Attribute:"
Me.Label19.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox20
Me.TextBox20.Location = New System.Drawing.Point(149, 491)
Me.TextBox20.Name = "TextBox20"
Me.TextBox20.Size = New System.Drawing.Size(234, 20)
Me.TextBox20.TabIndex = 38
'Label20
Me.Label20.Location = New System.Drawing.Point(9, 487)
Me.Label20.Name = "Label20"
Me.Label20.Size = New System.Drawing.Size(134, 26)
Me.Label20.TabIndex = 37
Me.Label20.Text = "Attribute:"
Me.Label20.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox21
Me.TextBox21.Location = New System.Drawing.Point(149, 517)
Me.TextBox21.Name = "TextBox21"
Me.TextBox21.Size = New System.Drawing.Size(234, 20)
Me.TextBox21.TabIndex = 40
'Label21
Me.Label21.Location = New System.Drawing.Point(9, 513)
Me.Label21.Name = "Label21"
Me.Label21.Size = New System.Drawing.Size(134, 26)
Me.Label21.TabIndex = 39
Me.Label21.Text = "Attribute:"
Me.Label21.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox22
Me.TextBox22.Location = New System.Drawing.Point(149, 543)
Me.TextBox22.Name = "TextBox22"
Me.TextBox22.Size = New System.Drawing.Size(234, 20)
Me.TextBox22.TabIndex = 42
'Label22
Me.Label22.Location = New System.Drawing.Point(9, 539)
Me.Label22.Name = "Label22"
Me.Label22.Size = New System.Drawing.Size(134, 26)
Me.Label22.TabIndex = 41
Me.Label22.Text = "Attribute:"
Me.Label22.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox23
Me.TextBox23.Location = New System.Drawing.Point(149, 569)
Me.TextBox23.Name = "TextBox23"
Me.TextBox23.Size = New System.Drawing.Size(234, 20)
Me.TextBox23.TabIndex = 44
'Label23
Me.Label23.Location = New System.Drawing.Point(9, 565)
Me.Label23.Name = "Label23"
Me.Label23.Size = New System.Drawing.Size(134, 26)
Me.Label23.TabIndex = 43
Me.Label23.Text = "Attribute:"
Me.Label23.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox24
Me.TextBox24.Location = New System.Drawing.Point(149, 595)
Me.TextBox24.Name = "TextBox24"
Me.TextBox24.Size = New System.Drawing.Size(234, 20)
Me.TextBox24.TabIndex = 46
'Label24
Me.Label24.Location = New System.Drawing.Point(9, 591)
Me.Label24.Name = "Label24"
Me.Label24.Size = New System.Drawing.Size(134, 26)
Me.Label24.TabIndex = 45
Me.Label24.Text = "Attribute:"
Me.Label24.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Dialog1
Me.AcceptButton = Me.OK_Button
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.Cancel_Button
Me.ClientSize = New System.Drawing.Size(500, 649) '(500, 363)
Me.Controls.Add(Me.TextBox24)
Me.Controls.Add(Me.Label24)
Me.Controls.Add(Me.TextBox23)
Me.Controls.Add(Me.Label23)
Me.Controls.Add(Me.TextBox22)
Me.Controls.Add(Me.Label22)
Me.Controls.Add(Me.TextBox21)
Me.Controls.Add(Me.Label21)
Me.Controls.Add(Me.TextBox20)
Me.Controls.Add(Me.Label20)
Me.Controls.Add(Me.TextBox19)
Me.Controls.Add(Me.Label19)
Me.Controls.Add(Me.TextBox18)
Me.Controls.Add(Me.Label18)
Me.Controls.Add(Me.TextBox17)
Me.Controls.Add(Me.Label17)
Me.Controls.Add(Me.TextBox16)
Me.Controls.Add(Me.Label16)
Me.Controls.Add(Me.TextBox15)
Me.Controls.Add(Me.Label15)
Me.Controls.Add(Me.TextBox14)
Me.Controls.Add(Me.Label14)
Me.Controls.Add(Me.TextBox13)
Me.Controls.Add(Me.Label13)
Me.Controls.Add(Me.TextBox12)
Me.Controls.Add(Me.Label12)
Me.Controls.Add(Me.TextBox11)
Me.Controls.Add(Me.Label11)
Me.Controls.Add(Me.TextBox10)
Me.Controls.Add(Me.Label10)
Me.Controls.Add(Me.TextBox9)
Me.Controls.Add(Me.Label9)
Me.Controls.Add(Me.TextBox8)
Me.Controls.Add(Me.Label8)
Me.Controls.Add(Me.TextBox7)
Me.Controls.Add(Me.Label7)
Me.Controls.Add(Me.TextBox6)
Me.Controls.Add(Me.Label6)
Me.Controls.Add(Me.TextBox5)
Me.Controls.Add(Me.Label5)
Me.Controls.Add(Me.TextBox4)
Me.Controls.Add(Me.Label4)
Me.Controls.Add(Me.TextBox3)
Me.Controls.Add(Me.Label3)
Me.Controls.Add(Me.TextBox2)
Me.Controls.Add(Me.Label2)
Me.Controls.Add(Me.TextBox1)
Me.Controls.Add(Me.Label1)
Me.Controls.Add(Me.TableLayoutPanel1)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "Dialog1"
Me.ShowInTaskbar = False
Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
Me.Text = "Dialog1"
Me.TableLayoutPanel1.ResumeLayout(False)
Me.ResumeLayout(False)
Me.PerformLayout()
End Sub
Friend WithEvents TableLayoutPanel1 As System.Windows.Forms.TableLayoutPanel
Friend WithEvents OK_Button As System.Windows.Forms.Button
Friend WithEvents Cancel_Button As System.Windows.Forms.Button
Friend WithEvents Label1 As System.Windows.Forms.Label
Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
Friend WithEvents Label2 As System.Windows.Forms.Label
Friend WithEvents TextBox3 As System.Windows.Forms.TextBox
Friend WithEvents Label3 As System.Windows.Forms.Label
Friend WithEvents TextBox4 As System.Windows.Forms.TextBox
Friend WithEvents Label4 As System.Windows.Forms.Label
Friend WithEvents TextBox5 As System.Windows.Forms.TextBox
Friend WithEvents Label5 As System.Windows.Forms.Label
Friend WithEvents TextBox6 As System.Windows.Forms.TextBox
Friend WithEvents Label6 As System.Windows.Forms.Label
Friend WithEvents TextBox7 As System.Windows.Forms.TextBox
Friend WithEvents Label7 As System.Windows.Forms.Label
Friend WithEvents TextBox8 As System.Windows.Forms.TextBox
Friend WithEvents Label8 As System.Windows.Forms.Label
Friend WithEvents TextBox9 As System.Windows.Forms.TextBox
Friend WithEvents Label9 As System.Windows.Forms.Label
Friend WithEvents TextBox10 As System.Windows.Forms.TextBox
Friend WithEvents Label10 As System.Windows.Forms.Label
Friend WithEvents TextBox11 As System.Windows.Forms.TextBox
Friend WithEvents Label11 As System.Windows.Forms.Label
Friend WithEvents TextBox12 As System.Windows.Forms.TextBox
Friend WithEvents Label12 As System.Windows.Forms.Label
Friend WithEvents Label13 As System.Windows.Forms.Label
Friend WithEvents TextBox13 As System.Windows.Forms.TextBox
Friend WithEvents Label14 As System.Windows.Forms.Label
Friend WithEvents TextBox14 As System.Windows.Forms.TextBox
Friend WithEvents Label15 As System.Windows.Forms.Label
Friend WithEvents TextBox15 As System.Windows.Forms.TextBox
Friend WithEvents Label16 As System.Windows.Forms.Label
Friend WithEvents TextBox16 As System.Windows.Forms.TextBox
Friend WithEvents Label17 As System.Windows.Forms.Label
Friend WithEvents TextBox17 As System.Windows.Forms.TextBox
Friend WithEvents Label18 As System.Windows.Forms.Label
Friend WithEvents TextBox18 As System.Windows.Forms.TextBox
Friend WithEvents Label19 As System.Windows.Forms.Label
Friend WithEvents TextBox19 As System.Windows.Forms.TextBox
Friend WithEvents Label20 As System.Windows.Forms.Label
Friend WithEvents TextBox20 As System.Windows.Forms.TextBox
Friend WithEvents Label21 As System.Windows.Forms.Label
Friend WithEvents TextBox21 As System.Windows.Forms.TextBox
Friend WithEvents Label22 As System.Windows.Forms.Label
Friend WithEvents TextBox22 As System.Windows.Forms.TextBox
Friend WithEvents Label23 As System.Windows.Forms.Label
Friend WithEvents TextBox23 As System.Windows.Forms.TextBox
Friend WithEvents Label24 As System.Windows.Forms.Label
Friend WithEvents TextBox24 As System.Windows.Forms.TextBox
End Class
