Attribute strange behavior. Don't save instance attributes.
javaxp
Automotive
ES
I'm suffering a strange behavior setting attributes.
I've made a journal that sets the attribute "PLIST_IGNORE_MEMBER" to selected components in an assembly.
If I use:
Code:
component.SetUserAttribute(attName, -1, attVal, Update.Option.Now)
the attribute is saved. But if I use:
Code:
 component.SetInstanceUserAttribute(attName, -1, attVal, Update.Option.Now)
the attribute is not saved at all.
I've found a relationed thread , but no clue about .
The code complete is:
Code:
Imports NXOpen
Imports NXOpen.Assemblies
''' <summary>
''' Asigna el atributo PLIST_IGNORE_MEMBER de las instancias seleccionadas
''' </summary>
Module SetAttributeToSelectedInstances
    Sub Main()
        Const attName As String = "PLIST_IGNORE_SUBASSEMBLY"
        Const attVal As String = "Yes"
        Dim session As Session = Session.GetSession()
        Dim nxUI As UI = UI.GetUI
        Dim selectCount As Integer
        Dim selobj As TaggedObject
        Dim component As Component
        Dim workPart As Part = session.Parts.Work
        Try
            'Numero de objetos seleccionados
            selectCount = nxUI.SelectionManager.GetNumSelectedObjects()
            'Si hay algo seleccion
            If selectCount > 0 Then
                'Recorre los elementos seleccionados
                For index As Integer = 0 To selectCount - 1
                    'Obtiene el elemento seleccionado
                    selobj = nxUI.SelectionManager.GetSelectedTaggedObject(index)
                    'Comprueba que sea un componente
                    If TypeOf selobj Is Component Then
                        'Convierte el elemento seleccionado a Component
                        component = CType(selobj, Component)
                        'Asigna el valor
                    End If
                Next
                nxUI.NXMessageBox.Show("Terminado", NXMessageBox.DialogType.Information, "Cambios completados correctamente")
            Else
                'Muestra mensaje
                nxUI.NXMessageBox.Show("Error", NXMessageBox.DialogType.Warning, "No hay ningun elemento seleccionado")
                component = session.Parts.WorkComponent
            End If
        Catch ex As NXException
            If nxUI IsNot Nothing Then
                nxUI.NXMessageBox.Show("Error", NXMessageBox.DialogType.Error, "Error ejecutando la macro")
            End If
        Finally
            'Libera la memoria
            component = Nothing
            selobj = Nothing
            nxUI = Nothing
            session = Nothing
        End Try
    End Sub
    Public Function GetUnloadOption(ByVal text As String) As Integer
        'Libera la libreria inmediatamente
        Return CInt(Session.LibraryUnloadOption.Immediately)
    End Function
End Module
Thanks in advance,
Javi
NX 12.0.2.9 MP14
