Autocad
aml78363
5
Can anyone tell me how do u transfer layers of one file onto other file and if we transfer it becomes a block and so then after transfer how do we explode the block.As we cannot use explode since it is a xref file.So then how can we explode that block?
If you just want to transfer layers, you simply insert the drawing with the desired layers as a block (not xref) into the subject drawing. No exploding required it automatically brings in all the layers. No xrefs.
Rik
