Dear PJ18,
If you are revising a FEA project not matter the FEA code brand used the important question here is if the task of
stress convergence was performed or not as part of the project, this is up the project author and in my opinion this should be included in any FEA project, as well as the corresponding element quality check, a task that seems that most FEA engineers forgot at all (Jacobian check?, what´s Jacobian?...): the target is to demostrate that the solution is mesh independent, basically run your model, show your stress solution, clone your study, repeat the meshing task increasing the mesh density (the target is doubling the total DOF) and run the analysis: if your new stress solution is in the range of say 5% to 8% then you can say that the stress solution is convergent, the mesh density is correct, the model stress solution is mesh independent, OK?.
In displacements the solution is practically directly convergent, not need to refine mesh, unless the mesh is very coarse!!. Of course, a quality mesh check is required as well, element quality is critical in the accuracy of the stress solution, and the rules of meshing should be followed, for instance: when meshing walls with solid elements a minimum of two elements in the thickness are required in order to capture stress gradient, etc...
In summary, today not any FEA code of the market is wrong, the name of the FEA solver is not the most important, the key is the engineer to be a FEA professional: it cost years, is simply a question of time ...
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB:
Blog de FEMAP & NX Nastran:
