Automatic assign callouts
Martin898989
14
Hey Guys,
two questions:
- is there any way to assign automatic callouts in my modelling assembly?
- can I use the same callouts in the drawings?
Thank you very much
Martin
Automatic callouts, can you elaborate on this ?
If one uses Teamcenter , there is an automatic callout which is synchronized from Teamcenter to NX.
this is applied to the assembly and propagates to drawings.
without teamcenter, if you use the NX partslist, the partslist will / can assign callouts to your components.
the p-list is sorted based on rules you set, and the callouts will be 1-n * based on the sorting.
* I think it might be numbered in other schemes as well but I have not seen that anywhere.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
