Averaging a variable value in 3 increments (Abaqus subroutines question)
Yunus9696
IR
Dear colleagues
Hope you're great.
Using USDFLD subroutine, I want to choose material properties for the new increment based on the average of a variable (eg. S11) in last 3 increments.
Do you have any idea that how can I do so?
For example, how can I call the value of S11 in previous increment and the increment before that to add up with the value of S11 in the current increment and calculate the average of these three 3 values?
Best regards,
Yunus.
You will likely have to utilize state variables for this purpose. They can store the data for further use in subroutines.
Dear FE way
Thanks for your reply.
I tried to know how to get benefit from STATVs to have access to the previous increments results but the STATVs seem to work only in the current increment.
I ran a model consists of only one element and one integration point (CPS4R shell element) for only 3 increments.
I expected that I would have approximately 3 STATVs
(number of element * number of integration points * number of STATV * number of increments = 1*1*1*3= 3)
I asked my subroutine to write the following STATVs in the 3rd increment:
SUBROUTINE
if (KINC == 3) then
Write(*,*) "STATEV(1)= ",STATEV(1)
Write(*,*) "STATEV(2)= ",STATEV(2)
Write(*,*) "STATEV(3)= ",STATEV(3)
Write(*,*) "STATEV(10)= ",STATEV(10)
Write(*,*) "STATEV(20)= ",STATEV(20)
Write(*,*) "STATEV(100)= ",STATEV(100)
Write(*,*) "STATEV(-10)= ",STATEV(-10)
end if
STATEV(1) = S11
RETURN
END
And I got the following meaningless numbers (except the first one):
STATEV(1)= 333333.333333333 (equals to the S11 in the 3rd increment)
STATEV(2)= 399.930868952907
STATEV(3)= 0.000000000000000E+000
STATEV(10)= 1.00000000000000
STATEV(20)= 1.000000000000000E+036
STATEV(100)= 0.000000000000000E+000
STATEV(-10)= 9.999135446659966E-004
Do you know how STATVs work?
and How can I get the average of the current value of S11 and its value in 2 previous increments? (using STATVs or any other way)
Thanks for your kind attention.
