Not special in any way. Standard 24 or 28 volt bulbs when they are incandescent, or 12V in smaller/older propeller planes. Many instrument manufacturers buy an industry standard bulb from a source known for higher quality, but you can probably find the same bulb at a local auto supply. Many instruments today are LED or CCFL or other types that may require an authorized service facility. Normal system voltage may be typically 18V (engines starting) to 32V max with normal voltage of 27 to 28VDC.
BTW - in the truck market they may call it 24V. In the aircraft market they call it 28V. In either case it's the same voltage equivalent to two 12V car batteries.
