engtiuser2
I am looking for a fast and easy to detect the alignment (misalignment w.r.t horizontal plain) of the wood shaft (10mm diameter, 20cm long) which enters a work area. The shaft is to be fed along the its axis direction with feed rate of around 10 ft/s. The accuracy should be within 0.2 mm per ft.
