Good day,
I have been asked to supply reasons why SA53B - ERW pipe should not be used for hot oil (550F)applications. System max pressure is 125psi. As far as I can tell, the code does not show a reason to exlude it from this application, however the longitutal seam now has a .85 multipier for min. thickness calculations.
Any one had any experience with this?
