SnazyDragon
I have done my wall thickness calc for straight pipe which works for the fitting in my spec. Upon doing the calc for pipe bend with the same material I find that my intrados min wall thickness is higher than than w.t. of the fitting. Is there an exception in the code to get around this issue or do I certainly need to increase my wall thickness? Any help is much appreciated.
