Vis99
- Mar 29, 2013
- 12
- 0
- 0
If there is an electromagnet and a magnet system
Where the electromagnet is fixed and the magnet can move freely with low friction.
The gap between the two is 0. The orientations set-up in a way, that they repel each other,
Now I understood that EMF is generated when there is a "change" in the magnetic field, or simply put an interaction between to fields.
In my case, the interaction is from the electromagnet and the magnet, now here's my question.
When the electromagnet repel's the magnet is back EMF generated BEFORE or AFTER that interaction? I guess its after? Since then the change will occur.
