Looking for info on possible issues with back feeding a step down transformer. Currently have a mobile genset connected to the LV side of a 11kV to 415V delta star 2.5MW step down transformer. Normally this is used to supply power LV bus in one of our MCC's and kW limited to avoid back feeding. The breaker on LV incomer to the MCC has however failed and management have decided that we can back feed the transformer to prop up power supply when required. Site is island only with all other generators being 11kV. The LV genset is normally used as a back up when we bring one of the larger sets offline for servicing etc. I am not sure that I like the idea but have no solid argument to use against it so hoping to get an idea of potential issues.
Regards.
Regards.
