ClemsonVet
we have a 6" back flow DCDA serving a single private fire hydrant. Will be installed above ground in an enclosure typically called a "hotbox".
question:
When do you need a heater? Is there a geographical way to determine when its not necessary? We're in SC and it does freeze a couple dozen times each winter, however i understand the box itself may provide enough insulation from the elements to keep the device from freezing. Additionally we see above ground back flow prevention devices around simply wrapped in insulation materials.
If i can be steered toward regulatory / industry standard type guidance on this I would appreciate the help!
question:
