EngMan40
- Jan 11, 2009
- 66
The basement wall has a geocomposite sheet drain (geotextile and drainage core)
Any comment on the following claims:
1. that the flowable fill will clog the drainage by seeping through the geotextile when placed wet due to cement particles smaller than geotextile AOS.
2. that the flowable fill being a solid material will act as a barrier to groundwater and cause hydrostatic buildup behind the wall and drainage won't see groundwater at all.
3. that the flowable fill will crack eventually after it is set so it will allow groundwater to seep through.
4. that the flowable fill should be placed in small lifts to prevent overstressing the wall.
