backing weld
nabeel3
SA
I am working in a API 650 tank project where the WPS is combo of GTAW (root) + SMAW. The welder is qualified as with backing for SMAW. If the contractor decides to proceed with SMAW in root also using same WPS, can the same welder who is qualified previously perform the welding including the root . The welder will grind from other side the backing weld he deposited.
Hire someone who knows the code/standard.
You should not be getting paid if you have to ask questions like this on an internet forum.
This is the same question you previously asked...? Follow DekDee's advice...
