Balanced/Unbalanced Snow Load - Dome - ASCE 7-16 Example (2)?
Howlyn2
ASCE 7-16's commentary does a fine job giving snow load examples in the commentary. However, for example #: 2 the building with a 80' span and 15' rise circular arc has given me pause. Truthfully, the snow loads make sense but how does ASCE 7-16 justify the distance from 30 deg. slope (30'), and slope at the eaves = 41 deg.? They state "by geometry" and I'm having a tough time matching. Although this isn't the core of the problem, I want to understand. I've tried circular arc equations, etc. and cannot find these values. What equations is ASCE 7-16 using to find these distances and angles? Thank you.
You just need to determine the radius of the roof and the angle at the eaves to get the slope at any point. The eave x-coordinate is R*sinθ, and it is 40 feet from the crown. Its y-coordinate is R*cosθ, and it is 15 feet below the crown, so you have two equations:
R*sinθ = 40'​
R - R*cosθ = 15'​
This results in R = 60.8' and θ = 41.1°
The angle, θ, is also the roof slope (it is 90° from the radius line), so that gets you your slope at the eaves. The x-coordinate where the slope is 30° will then be at R*sin(30°) = 30 feet.
There are other methods to calculate the slope angle at the eaves .
Assume the center of the roof dome circle at origin . The formula of the circle of the dome;
X^2 +Y^2= 60.8^2
The derivative of the circle at any point is also the slope of the tangent line at that point.
so dy/dx= - 2x/2y= -x/y
The coordinates of the eave will be = 40 , (60.8-15=45.8)
and the slope dy/dx=40/45.8=0.873 ( slope is the TAN of the angle)
ATAN(0.873)=41.13 degr.
