Luke Goedecke
I am looking to make an approximately 6'0" x 8'0" hole in an existing 4"concrete floor structure. This is to allow HVAC equipment to be installed in the attic
It is going from the 2nd Floor to an attic. This is merely an access hole. It is my intent to infill the concrete opening later with a Shaftwall system whereby in the future there will be an access point to load equipment into the attic.The A/E has proposed ripping out all the concrete and barjoists and then replacing it from wall to wall and installing W12 beams which I believe is major overkill. Can anyone provide any connection detail to remove and retrofit the barjoists as I want to do?
