Wiredguitarist
- May 1, 2011
- 2
I've been an avid reader of these forums for over a year now but this will be my first post. I thank the community for providing such a valuable resource to fellow engineers.
Attached are two photos where beam pocket failure occurs in the basement of my house. These offset stacked beams are used to support the step-down living room above. Since there are no corner bars present, I have to assume the contractor used plain concrete with minimal reinforcing.
I'm looking for some guidance on repair techniques. I would assume that drilling and setting some corner bars with epoxy would allow a new corbel to be formed from the corners and support the beams more adequately. I have some concerns with finding a contractor that will be able to build the formwork and pour concrete into a confined area. Another solution might be to embed anchors on both walls extending from the corner and provide a steel shelf angle to pickup the beam?
As a recent grad, very little was covered in my coursework on concrete repair so I don't have much reference to work from on this. All ideas for repair are welcome, thank you.
