JohnnyB_
- Feb 1, 2022
- 84
Hello -
I am trying to calculate wind pressures and I am confused on the basic wind speed as noted in ASCE 7-10 Chpt 26. Per Figure 26.5-1A for Risk category II (residential) structures the design 3-second gust is 115 mph. This is self explanatory to this point.
Where it gets confusing is the local county code states, "Wind Load: The minimum basic wind speed for determining design wind pressure at any site shall not be less than 90 miles per hour, 3 second gusts sustained (115 ultimate)."
Per the county's direction am I to use 90 mph or 115 mph for the basic wind speed, when calculating wind pressure per Chpt 27 of ASCE 7-10?
Thanks in advance.
Thanks in advance.
