Basis Of working pressure Asme B16.5 1
AliGrailly
IR
Hi engineers
I want to know how to obtain working pressure of flange 600# at 38 degree equal to 102.1? Material A105
Appendix B in B16.5 not clearly describe just mentioned formula that cannot achieve it also Asme Viii Appendix 2
Stress value ÷ 8750 × 600
if stress up to 40 celcius =161 mpa
161 × 145 ÷ 8750 × 600 ÷ 14.5 =110.4 bar not 102.1
AliGrailly, I'm working on US units here, so bear with me.
Referring to B16.5 (2003) B2.1, B2.2, B3 and Sec II, Part D (2017) I get the following:
C1 = 1.0
Pr = 600
pc = 1500
S1, from B2.2:
(a)(1) = 60% of 38 ksi = 22800 psi
(a)(2) as above, T = 100 F
(a)(3) = 1.25 * 25% of 70 ksi = 21875 psi
S1 = least of, S1 = 21875 psi
This gives pt = 21875 / 8750 * 600 = 1500 (103.4 bar)
This is equal to pc, but greater than the Table F2-1.1 rating, 1480 psi or Table 2-1.1 value 102.1 bar
I can't explain the discrepancy, but I believe your value of S1 161 Mpa / 23351 psi is too high.
Forget Apx 2, the basis between it and B16.5 are not comparable.
Mike
Hi and thanks Friend : SnTMan
ref to table Y-1 Asme section ii part d Yield strength at temp 40 celcius for material A105 was 248mpa ~ 36000 psi
Asme B16.5 - Appendix B
B2.2
a(1) 60% of the specified minimum yield strength at38°C (100°F)
248×145.0377×60%÷8,750×600~1480 psi
1480÷14.5~102.1 Pr
As you told before 1.25×25%×70000÷8750×600=1500 Pc
Pr<=Pc
Now in table Y-1 Tensile str for A105 At Temp 40(c) is 248 and at temp 65 (c)= 233 how to obtain Yield Str at temp 50(c)?
AliGrailly, well I see I have performed some "sloppy work". Specified Minimum Yield Strength of SA-105 is indeed 36 ksi at 100F, as shown in both Table 1A and Table Y-1
This makes S1 = 21600, and pt = 1481 psi / 102.1 bar.
Thanks for the catch :)
Intermediate values may be found by any rational interpolation scheme.
