structSU10
I am trying to determine connection requirements to provide appropriate bracing of a wale beam. It is a double channel wall laid flat, resting on sheet piles with tie back anchors inset 2-3' from the wale beam ends. The argument was over the need for a positive attachment at support / bracing points, assuming friction along the compression flange would be adequate to brace the wale.
Where this argument falls apart is near the short cantilever where the compression flange is away from the sheeting. Even with stiffeners I find it hard to justify the stability without positive attachment. The wale has a bracket to rest on and would need to twist upward which would try to kink the tie back - is there some form of stability provided by the prestressed anchor?
