im designing the beams for a preliminary requirement included on my first project inquiry (the same project ive asked before). it turned out that the assumed dimensions were smaller than those i had computed in my design. it was taught that if the design dimension is greater than the assumed, i have to start again the load analysis with a greater dimension and repeat the procedures for the design until the resulting dimensions are smaller or equal to the assumed or preliminary design.
is there anything i can do so as not to repeat the computations?
thank you for any help.
