DCBII
- Apr 15, 2010
- 187
I have a CMU partition wall with wide flange roof beams over it. The CMU is notched around the roof beams so they can pass over the wall without bearing on it. I need to seal off the spaces on each side of the wall from each other. How do I seal off the pockets around the beam? I can't use anything that transmits load from the beam to the wall. Dry-pack mortar or grout is out of the question. Is anyone aware of any products that can tolerate the beam deflection while keeping a seal?
