Hi there, I am hoping to get some insight on beam over column connections and erecting practices. I have a design that has 4 columns (labeled as c in attahced) vertically installed between w12x96 beams (labeled as b in the attached). The columns are 10 ft long, 8x8 tubes with 1" thick top and bottom plates. The beams and column plates are intended to be pre drilled prior to assembly. I am concerned that if the beam flange is not square, it will skew the column such that it won't line up with the holes in the beam above it. Are slotted shims normally used to plumb the columns in this type of connection?
Thank you.
Thank you.
