JStructsteel
When putting beam reactions, the engineer specified the total is DL+LL (ASD). Would that be used thru the shop drawings and connection design, or would you try and break it down to be able to LRFD the connections?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
JStructsteel said:I suppose that ASD could just be used thru the connection design process, and not worry about it.
cliff234 said:whether the loads are service level or factored
lexpatrie said:Why not set up all the standard stuff as dual format ASD/LRFD?
