TTTKAO
Mining
- Aug 24, 2022
- 79
Hello Friends,
Does anyone can advice how to check section capacity at a spot with big bending moment and shear force relatively by using of AISC 360-10 code ? I only found check the bending strength capacity as per chapter F and shear capacity as per chapter G separately.
1. Is there any requirement or combined equations to check existing moment and shear at the same time? such as Canadian code requirement CAS-S16-01 items 14.6. seems this combined load check is required by other nation code as well, is there any reason there is no requirement in AISC360-10 or i didn't find correct item to check ?
2. this is relating to item 1, for the built-beam or cover plate connecting weld size check, only shear force stress check at the weld location as per AISC chapter F13, there is bending stress existing, why this is not considered ?
Thank you in advice for your input and advice.
Regards!
Regards!
