Michael1968
- May 20, 2007
- 10
Hello experts,
I still had this question in Mechanical Acoustics/ Vibration engineering, but I think, it is better here in the bearing forum.
I'm doing a rotordynamic analysis (in ANSYS) of a shaft with journal bearings. There are time-independent loads (fixed in space) and unbalance. The journal bearings are simulated with matrix27 stiffness and damping elements with unsymmetric factors (C11, C12, C21, C22, D11, D12, D21, D22). I make a transient analysis with unbalance load. If I make a fsum in ANSYS of the matrix27 elements (both, stiffness and damping) I get periodic forces and I see, that a very large amount of the sum comes from damping ! I now want to check the pressure on the (stationary) bearing housing (outer part..). Which forces come to the bearing housing ? Do both come: stiffness and damping ? Which force would you take for calculation of a dynamic pressure on the stationary part ?
Thank you for your comments.
Michael
Michael
