Is bearing pressure the same as contact pressure?
Are these terms/concepts separated by soil structure interaction?
For example, if I have a box that is 10ft x 10ft in plan, 1-ft height fill with water, bearing pressure exerted will be 62.4 psf.
But because the ground responds uniquely, the actual contact pressures may vary.....although commonly assumed to be uniform.
