phamENG
- Feb 6, 2015
- 7,519
I have a somewhat unique condition (thanks, framing contractor!) and I'm realizing that AISI doesn't have a bearing check - am I right or just missing something?
I specified some bypass deflection clips to connect the offset wall to a steel beam. Rather than do that, the framer made their own "clips" out of track. They actually work (barely) in tension, but in compression they have to bear on the flange of the beam. They cut the flanges of the track so it could sit on top of the top track and have the 'lip' of the web slip under the beam and fasten to the flange. So I have .00825in2 of bearing area at each track flange.
I'm assuming there's a combined local stability/yielding combination to be considered. Just not entirely sure.
This is mostly academic at this point - I'll be giving them a corrective detail. But I'm curious if anyone has more insight. Thanks.
