NewEngInField
- Oct 24, 2022
- 2
Bearing Stress Formula
fbr=P/(D)(t)
where:
Fbr= Bearing stress (Pa)
P= Force of Load (N)
D=Diameter of Bolt
t=thickness of plate
Bearing Strength
Rn=(2.4)(0.75)(d)(t)(Fu)
where:
Rn= Bearing Strength (N)
Pa= Yield Strength (Pa)
D=Diameter of Bolt
My question is, what are the differences between both formulas. Assuming if I replace the value of bearing stress with yield strength, the value of calculated Force of load will not be the same as Bearing strength. Which of these formulas should I use to determine the limiting factor while designing?
fbr=P/(D)(t)
where:
D=Diameter of Bolt
Bearing Strength
where:
D=Diameter of Bolt
