Bearings
Juice
Hey everyone,
my question is a dumb question because i should know this. But How do you find the bearing of a line in World UCS. I have acad 14 but can access Acad 2000 if needs be. Sorry for the dumb question.
Thanks Juice
I assume you mean bearings with units of 'North xx degrees xx minutes xx seconds East' or similar. Under format units, select "surveyor" for angles units. Then when you list properties it will display bearings for the line's angle.
Carl
Similar threads
