Sicilian Engineer
- Oct 20, 2024
- 9
Hi All,
I'm looking for some advice on this robotic design I'm working on.
Mostly with the transmission. The motion of the system is as shown in my little vid below.
For reference the links are approx. 1.5m, and one can say there is a 600N point load in the centre of the horizontal link.
I want to mount the motors as proximally as possible (because they are quite big) so I need to figure out the optimal transmission to achieve this.
To me a cable driven system makes sense (high stiffness, no backlash (minimal I guess), great for systems with under 360 deg rotation). But for assembly it essentially isn't feasible with what we can use.
I think chain and sprocket are not usable due to backlash, lubrication, and repeatability concerns.
Which brings me to belts. I have never used a sync/timing belt for such a high torque application (base motors experience up to 700Nm) and essentially want to know if is feasible to use them, what to consider (double belts?, some non polyurethane advanced material (would prefer not to for cost)?, Multiple stages for further reduction? (speed is no issue)).
Also would it be insane to drive the first stage with a timing pulley fixed on the shaft AND have a timing pulley on a bearing on the same shaft, drive this with a separate motor and transfer from this shaft to the final stage?
Literally any help / thoughts /critique are welcome
can provide drawings to clarify any & everything
