Mohammad Saad
Hi everyone, hope you all are doing well.
I wanted to ask if we can calibrate the pilot PSV (removing the pilot part from the main valve) by connecting its inlet directly to the test bench? Apparently, there seems to be no issue in that but are there any precautions to be taken or code restrictions to keep in mind? The situation is that we have to check/calibrate the pilot PSV but we cannot bring the whole PSV to the testing shop. So we are trying to just bring the pilot part of the psv.
