ZeroStress
I'd be grateful if anyone can guide me in the right direction.
A flat plate 2m x 2m with a thickness of 20mm (Stainless steel with fy = 220 N/mm2) is supported on two of its parallel sides and a its acting as a wall inside a chamber. The loading on this plate is a hydro static load.
Am I correct in assuming that the lateral torsional buckling isn't relevant to this case as the plate is not in pure compression. The plate experiences stress variation going from tensile to compressive through its thickness. As the entire thickness of the plate isn't in compression, the lateral torsional buckling is not valid which would mean the plate can't undergo LTB under this load, hence it would always be a compact section. So in order to design the plate (i.e. check to see if the thickness is adequate), I'd just compare its extreme fibre stresses with fy = 220 MPa (divided by material factor for ULS).
Is this approach correct?
Thanks.
Thanks.
