SeizeTheMoment
- Sep 16, 2020
- 30
Hello all, I would like your input on how you would analyze the tolerance of a bent chord of a joist, or if you have any resources available.
I've looked at TD12 and their commentary is that "if local buckling exists in chords subjected to compression, the buckled sections should be alleviated or reinforced. Buckled sections in chords subjected to tension only may not be detrimental to the joist performance depending on the degree of buckling. More than likely local buckling in tension chords occurred during shipping or erection."
Is there guidance on how much an angle can buckle in compression without needing reinforcement, and has anybody checked the case for tension chords as well?
See sketch below for the typical tolerance in question.
Thanks in advance.
Thanks in advance.
