Best location for control valve inlet or outlet?
MechEng92
GB
Where is the best location for a control valve in a chilled water system, on the inlet or outlet of the cooling coil?
I recall reading somewhere that outlet is better as it provides a full coil of liquid at all times and temperature change reacts better to cooling demand.
Outlet.
It's a closed pressurised system?
This shouldn't allow any part of the system to fall below a certain pressure so you're not going to get any draining or air in the system
Then it makes virtually zero difference.
Inlet the system will see a slightly lower pressure, but should still be capable of seeing full design pressure
Outlet then coil will always be packed at inlet pressure.
Just make sure the flow direction on the valve is correct!
Thank you, it will be a closed system.
What is the benefit of it being on the outlet? Does having a full coil prevent noise from water hammer? Is there quicker temperature control response?
On the assumption that it is
a) A closed system
b) The cooling coil is fully vented and full of water
What is the benefit of it being on the outlet? - There isn't one (IMHO)
Does having a full coil prevent noise from water hammer? - NO
Is there quicker temperature control response? - NO
hydraulically it doesn't' matter in a closed system.
the small advantage of locating it at the outlet of a hot or chilled water coils is a bit less extreme temperature at the valve, and little less pressure.
Excellent, thanks very much EnergyProfessional :)
