Marc Rogue
- Jul 30, 2021
- 19
Hello guys, I was given the task to design the connection for a sign to be supported by a block wall. I came up with 2 rectangular hss3.5”x3.5”x5/16”
Per support Top and bot connected to the wall ( total of 4 supports) spaced every 4’ or so. My question is my approach was to firstly calculate wind loads(I’m in Florida) using asce 7-22 chapter 28 and then proceed to analyze the load on the sign due to wind with an eccentricity of 1.5” from the c/l of the top HSS. My question is the concrete screw manufacturer provides specification for shear and pull out strength but not tensile strength. Also the screws would be going into blocks which may not be filled with grout so I don’t feel to confident they would hold. Anyone has experience with this?
