cubalibre000
- Jan 27, 2006
- 1,070
I've imported a plastic part made with other CAD.
I need to make some modifications via ST and some blends must be removed.
Now I need to recreate these blends.
As you can see in the 'blend' image, the radius in the hole on inclined surface is 'constant'.
All blends on this part are like this.
I'm trying to create blend, but as you can see in the 'blend nx' image, the behavior is different.
There is an option in the blend command to obtain this result ?
Thank you...
Using NX 8 and TC9.1
Thank you...
