blending
gilbo6
IE
hi,
Im trying to draw a section of a machine which starts off as a round pipe and changes into a pentagon shape. What command will i use to achieve this. I tried to blend but it wont let me do it with different sections. any help would be appreciated
You need to use blend but you have to break up your circle into sepperate arcs. Remember you can collapse segments in one section into points in the next section if that is what you want.
That has worked perfectly. Thanks a million. Have been pulling my hair out all day over that.
Gilbo
