Unless you are in an area that has this as a code requirement, as long as the bottom of the excavation is stable, relatively dry, non-reactive to concrete, and compactible, then there is no reason you would have to use a blinding layer. Provided you have adequate cover on the rebar, concrete may be cast against earth.
