Block UI Styler apply changes
issamo
Student
Oct 29, 2024
1
Hello everebody ,
I'm totally new on programming , I'm using just Chat GPT to understand what the code means . I have UG NX 2303 version, and I've used Block UI Styler ,because I want to create a shortcut example : if user have sheet size A0 and he want to update it to 6A0 , only by clicking to this journal he can update it quickly . the issue now is the apply cb , even I asked chat GPT but ig give me always error and it can't be applied .
could you help me please
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.BlockStyler
'Represents Block Styler application class
Public Class list_box_bitmap
'class members
Private Shared theSession As Session
Private Shared theUI As UI
Private theDlxFileName As String
Private theDialog As NXOpen.BlockStyler.BlockDialog
Private group0 As NXOpen.BlockStyler.Group' Block type: Group
Private list_box0 As NXOpen.BlockStyler.ListBox' Block type: List Box
#Region "Block Styler Dialog Designer generator code"
'Constructor for NX Styler class
Public Sub New()
Try
theSession = Session.GetSession()
theUI = UI.GetUI()
theDlxFileName = "C:\Users\iennadif\Downloads\list_box_bitmap\list_box_Format\list_box_Format.dlx"
theDialog = theUI.CreateDialog(theDlxFileName)
theDialog.AddApplyHandler(AddressOf apply_cb)
theDialog.AddOkHandler(AddressOf ok_cb)
theDialog.AddUpdateHandler(AddressOf update_cb)
theDialog.AddInitializeHandler(AddressOf initialize_cb)
theDialog.AddDialogShownHandler(AddressOf dialogShown_cb)
Catch ex As Exception
'---- Enter your exception handling code here -----
Throw ex
End Try
End Sub
#End Region
Public Shared Sub Main()
Dim thelist_box_bitmap As list_box_bitmap = Nothing
Try
thelist_box_bitmap = New list_box_bitmap()
' The following method shows the dialog immediately
thelist_box_bitmap.Launch()
theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
Finally
If thelist_box_bitmap IsNot Nothing Then
thelist_box_bitmap.Dispose()
thelist_box_bitmap = Nothing
End If
End Try
End Sub
Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
Return CType(Session.LibraryUnloadOption.Immediately, Integer)
' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
End Function
' Following method cleanup any housekeeping chores that may be needed.
' This method is automatically called by NX.
Public Shared Sub UnloadLibrary(ByVal arg As String)
Try
End Try
End Sub
'This method launches the dialog to screen
Public Function Launch() As nxopen.blockstyler.BlockDialog.DialogResponse
Dim DialogResponse As nxopen.blockstyler.BlockDialog.DialogResponse = nxopen.blockstyler.BlockDialog.DialogResponse.Invalid
Try
DialogResponse = theDialog.Launch()
End Try
Return DialogResponse
End Function
'Method Name: Dispose
Public Sub Dispose()
If theDialog IsNot Nothing Then
theDialog.Dispose()
theDialog = Nothing
End If
End Sub
'Callback Name: initialize_cb
Public Sub initialize_cb()
Try
group0 = CType(theDialog.TopBlock.FindBlock("group0"), NXOpen.BlockStyler.UIBlock)
list_box0 = CType(theDialog.TopBlock.FindBlock("list_box0"), NXOpen.BlockStyler.ListBox)
Dim list_box0Props As PropertyList = list_box0.GetProperties()
Dim list_box0Values() As String = {"A4", "A3", "A2", "A0", "2A0", "3A0", "4A0", "5A0", "6A0"}
list_box0Props.SetStrings("ListItems", list_box0Values)
End Try
End Sub
'Callback Name: dialogShown_cb
Public Sub dialogShown_cb()
Try
'---- Enter your callback code here -----
End Try
End Sub
'Callback Name: apply_cb
Public Function apply_cb() As Integer
Dim errorCode as Integer = 0
Try
errorCode = 1
End Try
apply_cb = errorCode
End Function
'Callback Name: update_cb
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
Try
If block Is list_box0 Then
'---- Enter your code here -----
End If
End Try
update_cb = 0
End Function
'Callback Name: ok_cb
Public Function ok_cb() As Integer
Try
errorCode = apply_cb()
errorCode = 1
End Try
ok_cb = errorCode
End Function
'Function Name: GetBlockProperties
'Returns the propertylist of the specified BlockID
Public Function GetBlockProperties(ByVal blockID As String) As PropertyList
GetBlockProperties = Nothing
Try
GetBlockProperties = theDialog.GetBlockProperties(blockID)
End Try
End Function
End Class
